siuolly's avatar
Apr 30, 2018
RB50 and RBS wire backhaul speed
I have the RB50 with one satellite using wire backhaul.  Standing right next to the RB50 (router) and do a speed test can go as far as 200Mbps (using the latest firmware 2.1.4).  However, when I stand right next to the satellite, I am getting max 60Mbps..(wireless backhaul is some what the same or worse because the distant and wall).  I that all I get.  For wire backhaul I though I'll be do much better than the wireless.
1 Reply
  • FURRYe38's avatar
    What mobile device are you using to test next to the Satellite?
    What speed test app are you using to test?
    Connect a wired PC to the satellite and speed test with a browser and speedtest.net on the PC thru the satellite.
    What are the speeds UP and Down to you pay for?
    Whats the Mfr and model# of the ISP modem?
