olivierwa's avatar
olivierwa
RB50 as AP - No Internet connection despite all devices connecting fine
Hello, I have a RBK50 set as wireless AP and connected to an internet modem Huawei model B715s-23c. (4G modem) The RBR50 is connected via its Internet port (yellow on the back) to the ethernet port...
  • olivierwa's avatar
    olivierwa
    Nov 18, 2021
    I actually found the issue and sharing it with the forum in case someone has a similar issue.
    My 4G Huawei modem's configuration (model B715s-23c) changed from "IP V4 only" to "IP V4 + IP V6". The change probably happened via a firmware update.
    It seems that the netgear was not able to connect with such settings. This was true as well for my Sonos devices. I switched it back to IPV4 Only and everything connected propery include the netgear RBK50. The settings on the modem can be found under the APN entry
    I hope this will help other people.
