bashfulrobot
Mar 30, 2018Tutor
Rb50 constant traffic interruptions
I just got my Orbi system in December. I constantly have issues where devices take forever to load (if at all) web pages, on the internet and the lan. As well as things like my Roku accessing my Plex ...
Apr 25, 2018Guru - Experienced User
Both wired and wireless devices?
What channels are you using on the router? Try manual 1, 6 or 11. Any unused channels on 5Ghz.
Try setting 40Mhz only channel width.
Disable IPv6.
Set manual DNS addresses, 1.1.1.1 and 9.9.9.9 on the router under Internet Settings.
Disable MIMO, Daisy Chain and Fast Roaming on the router and reboot.
