ClintoKL
Sep 12, 2023Apprentice
RB50 Orbi Pink Light
My Orbi Router is showing a Pink Ring Light after a recent reboot. I use the Orbi Router in AP Mode. I have an Asus RT-AC68U that I use as my Router. My entire system is working just fine. I have 3 satellites, all working just fine. Internet is just fine. The only thing is the Pink Ring Light. I have rebooted/restarted it a few times since seeing this and still the Pink Ring Light appears after the boot up flashing White Light. The satellites boot up correctly (i.e white flashing light and then blue ring light which eventually turns off). But the router just shows a constant Pink Ring Light that never turns off.
Anyone experience this or have any ideas.
1 Reply
Try powering OFF the host router and RBR for 1 minute then back ON?
