NIL454
Jul 26, 2019Aspirant
RB50 speed issues finally solved
I finally after numerous calls and many setting changes incresed the speed of the Orbi, wired or wireless. By default the MTU was set at 1500. I have reduced the MTU to 1468 and my speeds have...
- Jul 26, 2019
I am aware of double NAT and tested to ensure that was not so. The modem is in modem mode with fixed IP (serving two other appliances with fixed IP), not running any DHCP or wirreless all that is controlled from the Orbi.
Speaking to NG this morning they never even asked about my modem or make. They were very clear 1500MTU is not optimal for the Orbi, but it should be reduced. I did this an within an hour the speeds had increased dramatically.
