scottmph
Apr 13, 2020Aspirant
RB50 Suddenly blocking my sites
so this morning Orbi has decided to block all my personal sites and my VPS signin to WHM with leaseweb It happens on any divice I use that uses the wifi. I can get if I go through my vpn at w...
Pal2999
Jun 15, 2020Aspirant
Having the same problem
Jun 15, 2020Guru - Experienced User
Armor, Circle. Save settings and reboot the router and satellite(s).
- Pal2999Jun 15, 2020AspirantFirmware V2.5.1.16
Virgin media router in modem mode
Circle disabled I don’t have armour- FURRYe38Jun 16, 2020Guru - Experienced User
You might try a factory rest on the RBR and setup from scratch. IF you had Circle enabled at one point then disabled it, there could be lingering problems.
