DoomGirDoom
Jun 30, 2021Follower
Rb50 wifi password works for minutes then stops on some devices
HopefullyI set that up correctlyBecause my orbee will not keep the password As Correct For Certain Devices. For some reason only my computer, my Echo show 5 and Galaxy S21 Ultra Are Having Issues. M...
Jun 30, 2021Guru - Experienced User
What browser are you using to manage the RBR?
Try setting a simple alphacharacter PW, 8 characters on the RBR.
