Sogavol
Nov 30, 2018Follower
RB53 vs RB50 for 5000. Sq ft
First of all I am not very tech savvy so thanks for any input.
i went ahead and got the 53 with 2 satellites figuring overkill would be better since I was wanting some coverage behind our house.
i just read something that each satellite use a dedicated band for backhaul to the router and that the extra satellite may actually clog up the system and hurt speed.
thanks for the help.
- st_shawMaster
You should be fine. I have one router and two sats in a 3,000 SF 3-level home with no issues.
I use a base router and just satellite for my 5000sq ft home.
Recommend 30 feet to begin with in between the base router and satellite(s).
Good Luck.I have the RBK50 with two RBS50 satelites for a 6000 sq ft home and it works great -- in fact I can get wifi out in my driveway all the way to the street. You should be fine.
