jon_curtis
May 22, 2019Follower
RB5S0Y Indoor outdoor mode
stuck in a loop whilst setting up Indoor Outdoor mode.. cant then escape as takes you constantly back within second to option page..
loomis1975
May 22, 2019Luminary
I've had a RBS50Y since the first beta involving it.
Its on firmware V2.3.0.28 now. The web browser pages for it, both status and debug you can't really control anything or any options.
From the main router pages, you can only manually turn on/off the LED on the unit or schedule when you want it to turn on/off. Also you can enable/disable the SYNC button on the unit.
I'll check out the app, see if anything is new, but mines been setup forever, I'm guessing its in tri-band mode unless firmware switched it to dual-band by default. I'll report back.
Edit: Checked out the App, there is no option to change the mode that the RBS50Y is in from the App once the unit is setup I guess. I would try what was suggested and try to set it up from the web browser "Add an Orbi Satellite" option and see what happens.
BobDelp
May 23, 2019Guide
What version of the Orbi App? What Country?
My Android app does Not have those option.
G27
