CFJ
Jul 15, 2020Aspirant
RBK 12 - Satellite light staying solid amber
The light of my satellite (placed in my study) stays a permanent solid amber during the last 2 days. The light of the router (placed in the living room) is a solid blue. What should I do to make the ...
Jul 16, 2020Guru - Experienced User
Try moving the RBS either closer or farther from the RBR.
Does the RBS appear in the RBRs web status page?
Factory reset the RBR and RBS and setup from scratch an add the RBS again.
- CFJJul 16, 2020Aspirant
Thank you for the suggestions. :))
