Thisted
Aug 17, 2020Follower
RBK 13 password
Where do I locate password on the RBK10 router. I purchased the RBK13 system with two satellites. Instructions indicate that it is located on a label but the only label on the unit shows SN and MAC. ...
Aug 18, 2020Guru - Experienced User
You can log into the device to access the ssid/password as well as change them.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
