Thisted
Aug 17, 2020Follower
RBK 13 password
Where do I locate password on the RBK10 router. I purchased the RBK13 system with two satellites. Instructions indicate that it is located on a label but the only label on the unit shows SN and MAC. ...
Mstrbig
Aug 18, 2020Master
The default user name is admin. The default password is password. The user name and password are case-sensitive.
To recover forgotten password:
- Launch your browser and go to my.netgear.com/registration/login.aspx
- Select the "Forgot your password?" option to access the "Reset your password" window.
- Submit the email address used when creating Orbi account.
- Fill other fields and click "RESET MY PASSWORD".
- Go to your email and open the link sent by NETGEAR Support.
- You should be redirected to the NETGEAR Change Your Password page.
- Enter a new password and click "Submit".
