Oppie2112
Oct 11, 2024Aspirant
RBK 13 Wi-Fi is working but ethernet says there is no Internet
All of a sudden, my hardwired ethernet connection PC is not connecting to the Internet, but all of my Wi-Fi devices are. What is going on?
Oct 11, 2024Guru - Experienced User
Power of the PC or reboot it?
Connect it to the back of the RBR or an RBS?
Swap Lan cables?
Does other ethernet devices show same thing?
Oppie2112
I have swapped out at least three different ethernet cables, and get the same error. I have spent hours trying to resolve this issue attempting various fixes to no avail. I am wondering if the ethernet connection to the Orbi router is bad.
- FURRYe38Oct 11, 2024Guru - Experienced User
Try a factory reset and setup from scratch on the system using a wired PC and web browser?
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2356834/highlight/true#M52575https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
- Oppie2112Oct 11, 2024AspirantThe first thing I’m going to do is try to bypass the router and hardwire directly into the modem first and see if that corrects the issue. If it does, then that would indicate that the Orbi is not working correctly with Ethernet and then I will proceed with the step you recommended
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
