mvillapa
Mar 23, 2020Aspirant
RBK 22 SERVER CONNECTIVITY ISSUES (Mac)
Hello, I was able to set up the Orbi and so far I am seeing improvements with my devices connected via Wifi, such as my Ring cameras. Unfortunately, there are a number of features that I had pri...
- Mar 23, 2020
With the server connected directly to the primary router, devices connected to the Orbi are on a differet IP subnet and will not see it.
The easiest solution is to use the ORbi web interface, Advanced Tab, Advanced Settings, Router/AP to change the Orbi from router to Access Point (AP) mode. That way, the primary router will assign IP addresses to all devices. They will all be in the same subnet.
Should work then.
CrimpOn
Mar 23, 2020Guru - Experienced User
Should work then.
mvillapa
Thanks so much. That was an easy fix. Everything appears to be working as it did before.
