Dway's avatar
Dway
RBK 40 - 1 of 2 satellites is not connected to main Orbi router
Hello; I was looking to find an optimal channel setting and when I was reviewing my connected devices, realized that one satellite (#1) is connected to the main Orbi router. The second satellite (#2 in our basement) is connected to the first satellite, not the main router. This does not seem correct. Please advise and if my hunch is accurate, how do I ensure that satellite #2 is connected to the main Orbi router? Thanks in advance, David
  • CrimpOn's avatar
    CrimpOn
    First, what seems "correct" to humans is not often what computers decide on.  My guess is that when the second satellite powered up, it decided the signal from satellite#1 was better than the signal from the router and connected to it.  There is a simple way to prevent satellite#2 from connecting to satellite#1:
    On the Orbi web interface, select the Advanced Tab->Advanced Setup->Wireless Settings.  About half way down the web page, uncheck the box "Enable Daisy-Chain Topology".  (I don't know if the router will reboot automatically or not.)  Then, restart each of the satellites.  This setting tells the router that satellite connections are only directly to the router.
    Be prepared for satellite#2 to be unhappy about this.  If the "ring light" does not eventually turn BLUE, then the router/satellite connection is not "Good".
    Good Luck
    • Dway's avatar
      Dway
      Good Luck
           Thanks for your reply. Satellite #2 has had its ring light go from purple to blue to unlit and seems to cycle fairly regularly. So, to your           point it may already be unhappy. Is the diabled daisy chain topology the recommended set-up? Thanks again, David
      • CrimpOn's avatar
        CrimpOn
        Once the ring light turns blue for 10 seconds, it should remain off from then on.  Your ring light does not stay off?
        My own personal belief (with no documentation to back it up) is that Netgear ships the Orbi router with Daisy Chain "Enabled" for a reason.  A lot of Orbi customers take it home, plug it in, and never look at the management interface.  People who own only smartphone and tablets may only open the "App", which does not access any of the advanced settings.  That way, someone can get another satellite, plug it in, and chances are it will connect and work.  They don't care about topology, just "Can I get to Facebook?"
        There are telnet commands which will show the exact status of the "backhaul" links.  (At some point, you may hit a point of "diminishing returns" in terms of poking around the Orbi.)
