Squonky
Jun 06, 2020Tutor
RBK 40 Firmware 2.5.1.16 Access control page blank
HI I updated to the above firmware, Now my satellite is shown as disconnected i the web client but not I the android all it is online. In the web clie t devices it shows I have access co trol tur...
TanMan1217
Jun 06, 2020Guide
I had different problems after the 2.5.1.16 update, but I resolved them by doing a hard reset on my base unit (mine's the RBR40). Using a paper clip, hold the reset button while the Orbi is on. Wait for the power light to flash amber, then release the paper clip. The router will then reboot. It will take 3 or 4 minutes before you will be able to connect. Note that it will reset to factory default, so you'll have to reconfigure using a wired device, or the app on your phone.
- SquonkyJun 07, 2020Tutor
TanMan1217 wrote:I had different problems after the 2.5.1.16 update, but I resolved them by doing a hard reset on my base unit (mine's the RBR40). Using a paper clip, hold the reset button while the Orbi is on. Wait for the power light to flash amber, then release the paper clip. The router will then reboot. It will take 3 or 4 minutes before you will be able to connect. Note that it will reset to factory default, so you'll have to reconfigure using a wired device, or the app on your phone.
Thanks, reset, and reload did not work
