Dway
Nov 13, 2019Aspirant
RBK 40 Internet speed issue
Hello; With my ISP, I am provisioned for 200 mbps service. This seems to be what is coming into the home and is available on the smart app when I do a speed test and with devices wirelessly attached...
Nov 13, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Do wire connected PC speed testing test good or same?
- DwayNov 13, 2019Aspirant
Thanks for your input. I decided to call Spectrum as the speed tests repeated on one device were varying a lot. They suggested changing from Ch 9 on 2.4 GHZ to channel 1, which I did. My call to them resulted in a service call scheduled for tomorrow. The firmware is up to date (V2.3.5.30). My satellite units are about 30 feet away from the main router. The ISP modem is an Aaris TM 1602. Home size is about 3200 s.f. (3 levels - main, upper and basement levels - the satellites are on the main level and in the basement). If there are WiFi neighbors, none are closer than 300 feet (only 1 at that short a distance). Right now, Daisy Chain, Fast Roaming, WMM and Beamforming are all enabled, and MU-MIMO and 20/40 MHz Coexistence are not enabled. Until Spectrum has completed their service call, I will not try any new adjustments - there's too much signal noise. I really appreciate the prompt response, David
- FURRYe38Nov 13, 2019Guru - Experienced User
Ensure the speed tests on the modem with a wired PC whille the tech is there. Then connect the Orbi up and speed test again with a wired PC thru the RBR with a speed test app.
