Jojo121278
Mar 17, 2018Star
RBK 40 vs. RBK 20
Was ist der genaue bzw. dezidierte Unterschied zwischen: RBK 40 vs. RBK 20? Würde mir gerne ein System anschaffen?
Jojo121278
Mar 17, 2018Star
Well, I want to buy an Orbisystem, and now I saw that there is an new Orbisystem, RBK 20! What´s the exactly difference between RBK 40 and RBK 20. The missing Lanports I still know, but there are other differences between those?
Thx for your answers
Mar 17, 2018Guru - Experienced User
Review all ths systems here and you'll see what they do.
http://netgear.com/orbi/systems.aspx
Chose one that best fits your needs and Sq Footage of your building.
