ameagari
Nov 14, 2018Aspirant
RBK 43 or RBK50?
Can someone tell me the difference between the RBK43 and RBK 50? I was all set to buy this at Best Buy when I realized the model that's on sale now is different from the one on sale on Black Friday, ...
- Nov 14, 2018
Either one would work, however you would only need the 1 satellite I think for 3000sq ft.
The 50 series just provides faster connection rates between it's satellite and connected devices is all.
Beginning distance between the base router and satellite should start at 30 feet.
ameagari
My dad says the sq footage is 2600.
So the RBK43 would likely be overkill? Is the only real benefit that it has a third sattelite in the pack?
It sounds like the RBK50 will provide faster wifi in some way?
Edit:
And my mom just corrected him, it's about 3000, but definitely under 5,000 sq feet.
Nov 14, 2018Guru - Experienced User
