WaltonGlade
May 12, 2019Aspirant
RBK 43 or RBK50?
Trying to decide between RBK43 and RBK50 (have seen some similar posts but they didn't really address my questions). My place is ~2000sqft, one floor, but my modem is fixed at one end of the house, a...
gr8sho
May 12, 2019Virtuoso
The wireless backhaul on the RBK50 is about the best there is. It's better than a 1Gbit wired Ethernet link in terms of raw performance. The satellite also provides four Ethernet ports that can be used to connect video streaming boxes for instance. Should easily handle your setup based on description. Won't comment on the 40 series as I do not have any direct experience with the product.
WaltonGlade
Much appreciated- I was veering toward the RBK50 so that;s probably what I'll do. Thanks for the input
