mdak1atl
Dec 02, 2019Tutor
RBK-43S blocks HULU, Pandora, other streaming
Just bought a RBK-43S orbi router with 2 satellites from BestBuy. Set up and all tells me working ok. I can connect devices to oribi network but once i go to stream an app like HULU, Pandora, etc...
- Dec 13, 2019
NOTE TO ALL
Thank you for the assistance.
- Changed ATT Modem - turned WiFi OFF
- Connected directly to ORBI via cable
- signed onto orbi login site;
- changed settings to AP
- ALL APPS working as expected.
thanks again
MDAK1ATL
mdak1atl
Dec 02, 2019Tutor
orbi firmware: V2.3.5.30
Modem is from ATT - Uverse
I do not see a mfr. but model number is 5268AC / FXN
Not sure if it matters, but when i open the Orbi App, dashboard shows the 2 satellites connected and any devices have i have connected. However, at the top, next to INTERNET it says "OFFLINE" but i can use the web for general purposes thru orbi
Hope that helps.
Dec 02, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
mdak1atl wrote:orbi firmware: V2.3.5.30
Hope that helps.
- mdak1atlDec 02, 2019Tutor
Thanks, seems abit complex for a novice network person like me. I will investingate the info and links. Thank you again. I have some questions down below in your text...
FURRYe38 wrote:Modem Combo Units:
This would be a double NAT (what is NAT?) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode. It ORBI not in router mode now?
Hope that helps.
- Retired_MemberDec 02, 2019
Network Address Translation (NAT) is the ability of a router to translate a public IP address to a private IP address and vice versa. It adds security to the network by keeping the private IP addresses hidden from the outside world.
When you hear people in here talk about NAT it's usually in a case of 2 routers in the same network.
if you did nothing to it, it probably is which is your problem since the AT&T device is probably also in the router mode.
- FURRYe38Dec 02, 2019Guru - Experienced User
mdak1atl wrote:Thanks, seems abit complex for a novice network person like me. I will investingate the info and links. Thank you again. I have some questions down below in your text...
This would be a double NAT (what is NAT? http://computer.howstuffworks.com/nat.htm
http://www.practicallynetworked.com/networking/fixing_double_nat.htm) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode. It ORBI not in router mode now?Yes the Orbi is in router mode. Need to get the modem either bridged fully with the help if your ISP or try option #2 below.
Hope that helps.
You'll have to keep the ISP Modem as ATT Uverse services require the use of the ISP modem and not a customer bought modem.
One other item, I would ask AT&T if you must use their modem. If not, I would dump the AT&T modem and buy your own modem only device.
Understood --- wish i could dump ATT all together!
