blamman
Feb 02, 2021Apprentice
RBK 50 admin login slow
Hi, Yesterday I had a few devices fall off the wifi network. A laptop, echo dot and wyze camera. The day before I did add a new lutron caseta light dimmer as I have 4 others of these. I was not...
- Feb 02, 2021
Ok, I would not recommend using older config files on newer version of FW. However if it works for you, sure. I would make a new back up config to file for safe keeping after checking the system out for a couple of days. :smileywink:
Feb 02, 2021Guru - Experienced User
What browser are you using? Try IE11, Edge or Firefox?
Try a different wired PC or laptop.
How did you update the RBR and RBS?
- blammanFeb 02, 2021Apprentice
Thank you. I have tried numerous browsers and computers. My phone app will not work also. I upgraded months ago just through the auto update from the browser.
Is the admin page dependent on internet as it does seem to be going up and down a bit.
- FURRYe38Feb 02, 2021Guru - Experienced User
I would try this, have same version of RBR FW file downloaded to one of your wired PCs already.
Disconnect the RBR from the ISP modem/ONT.
Press the back reset button for 15 seconds then release. Use MS Edge or FF browser and walk thru the setup wizard. Manually set up the RBR. Once on the RBRs web page, navigate to the Advanced Tab/Adminstration/Firmware Update section. Select the manual tab here and Browse button and select the unpacked FW file for the RBR and re-load the FW file.After the FW file gets sent and the RBR begins to process the file, clear out all browser caches and log back in to the RBR. I would do one more factory reset on the RBR, connect the RBR to the ISP modem then walk thru the setup wizard. I would avoid enabling Armor. Just setup wifi SSID and then sync any RBS.
Check the RBR web page for any slowness.
I followed your steps and seem to be doing better. I used an old config file I had also. Gui seems good and I was able to to add the devices that dropped and would not add back.
Thank you
I am going to watch it over the next few days.
