blamman
Feb 02, 2021Apprentice
RBK 50 admin login slow
Hi, Yesterday I had a few devices fall off the wifi network. A laptop, echo dot and wyze camera. The day before I did add a new lutron caseta light dimmer as I have 4 others of these. I was not...
- Feb 02, 2021
Ok, I would not recommend using older config files on newer version of FW. However if it works for you, sure. I would make a new back up config to file for safe keeping after checking the system out for a couple of days. :smileywink:
blamman
I followed your steps and seem to be doing better. I used an old config file I had also. Gui seems good and I was able to to add the devices that dropped and would not add back.
Thank you
I am going to watch it over the next few days.
Feb 02, 2021Guru - Experienced User
