superben79
Sep 04, 2017Apprentice
RBK 50 and RBW 30?
I have a RBK 50 and RBS 50. I need to expand wifi in one area. Instead of getting another RBS 50, can I add the plug in (RBW 30) instead?
- Sep 05, 2017
superben79 wrote:I have a RBK 50 and RBS 50. I need to expand wifi in one area. Instead of getting another RBS 50, can I add the plug in (RBW 30) instead?
Absolutely you can do this.
The RBW30 works with any of the other routers/satellites. You will need to manually add/sync the RBW30 as it will come with a different SSID/Password, but you can do this through the APP or the WEB GUI.
TC_in_Montana
Sep 05, 2017Virtuoso
