ajredaelli
Sep 18, 2020Tutor
RBK 50 Can’t Setup
I can’t find a way to setup. I have named my wi fi but the App seems to look for an Orbi92 - which does not exist! I’m at a loss. Someone please help. Online teacher and I can’t be off line. My unit a...
ajredaelli
Sep 18, 2020Tutor
I will try that - thanks.
Sep 18, 2020Guru - Experienced User
If you need, check the installation guide on NGs web page as well:
- ajredaelliSep 19, 2020Tutor
So .... I have also checked the installation guide, but I can't get it to work.
I did a reset on the Orbi. I connected via ethernet cable my laptop to an "Ethernet" port in the back of the Orbi, and I connected the "Internet" port to my modem. I typed 192.168.1.1 and it takes me to a login page. I do not see a setup page for my Orbi at all - I do see one for my Nighthawk, which of course is off-line during this process.
What am I missing?
