ajredaelli
Sep 18, 2020Tutor
RBK 50 Can’t Setup
I can’t find a way to setup. I have named my wi fi but the App seems to look for an Orbi92 - which does not exist! I’m at a loss. Someone please help. Online teacher and I can’t be off line. My unit a...
Mstrbig
Sep 19, 2020Master
ajredaelli wrote:
I can’t find a way to setup. I have named my wi fi but the App seems to look for an Orbi92 - which does not exist! I’m at a loss. Someone please help. Online teacher and I can’t be off line. My unit also had a satellite. Much appreciated.
Make sure bluetooth is turned on, on your device you are using to install the Orbi. Go into your device's WIFI network settings and look for the router WIFI and login.
I prefer using the app, as it is so much easier for me. So reset the Orbi router, reboot the modem it is going to connect to, plug in the Orbi and turn it on, load up the Orbi app and perform a new installation. Follow the instructions Verbatum. Once the Orbi router is up and running, follow instructions for the satellites. Once the satellites are up and running, move them to their location.
