StevensESS
Jan 17, 2021Aspirant
RBK 50 constantly losing Internet
Hi there Let me start by saying I'm not at all technical so looking for some help with clear instructions as most of the posts I've read I find really confusing. I have a Virgin Media Hub 3 and ...
Jan 17, 2021Guru - Experienced User
Try the modem in router mode and the RBR in AP Mode.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
StevensESS
Jan 18, 2021Aspirant
Hi Furrye38
Thanks for getting back to me.
Firmware version: V2.5.2.4
Virgin Media Hub 3.0 VMDG505/TG2492LG-VM
About 2,000 sq feet
Satellite is currently about 15 feet away from the router.
My channel for 2.4ghz was on auto so looking at another post i tried 6 and 48 for the 5ghz last night. so far this morning it has been more stable but my cams went offline once or twice during the night.
The post you shared says different channels and an older FW variant (the FW variant seems to come up a lot as many seem to have issues with one of the updates?
Would you suggest i try anything else before switching to ap mode?
Thank you for your help
- FURRYe38Jan 18, 2021Guru - Experienced User
StevensESS wrote:Hi Furrye38
Firmware version: V2.5.2.4< I would update to v40:
Built in router here by chance? if so,
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopAbout 2,000 sq feet
Satellite is currently about 15 feet away from the router. <15 feet is too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
