robpaul2501
Jul 27, 2021Aspirant
RBK 50 SATALITES NOT WORKING OK
Hi my satalites are not working correclty sine my armour expired. Will not play deezer, tune in, stopping my work laptop from working corrreclty.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Disable Armor on the Orbi app. Then power OFF the RBR and RBS for 30 seconds then back On. Check for RBS connections to the RBR on the RBS web page.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡- robpaul2501Aspirant
all firmware updated. just stopped working properly yhte other day RBV40. so if I disable armour it should be ok?
Try disable first, if that doesn't fix it, try a full factory reset on the RBR and RBS.
Be sure to post over in the Orbi with Voice for RBS40v help and information:
https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
Good Luck
