AAG53's avatar
AAG53
Tutor
Jun 01, 2018
RBK 50 sold by Verizon-special firmware?
I am considering purchasing an Orbi  RBK 50 system and I see that Verizon sells it. In their info, they state that they load a modified firmware to Orbi.
>>NOTE: Verizon-specific firmware and periodic updates will automatically be loaded onto your Netgear device at a future date. The firmware is not compatible with Orbi satellites purchased from another seller.<<
I am also considering buying the RBK 53, which is on sale at Costco. As I have Verizon FIOS, is there a big advantage to purchasing from Verizon so their FIOS specific firmware gets loaded?
  • I've got Fios and the Orbi.  I just use the Orbi as a wireless AP.  Yes, it is an expensive wireless AP, but it is smoking fast and cover my entire property with outstanding wifi service.  No problems here.
  • FURRYe38's avatar
    When using in AP mode, most features are not needed so there will be tradeoffs. AP mode is only that, wireless access point so no need for any of the routing features to be enabled. Been like this for a long time. Ya, it makes for a spendy AP system. Works though.
  • Thanks for the replies. I bought the RBK 53 from Costco since it was on sale for not much more that the RBK 50 elsewhere. Works great but I only needed one satellite.
    • FURRYe38's avatar
      What FW is yours loaded with?
      Awesome, Enjoy. :smileyvery-happy:
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    yes, If you purchase Orbi From Verizon, It has special VZ specific FW and firmware upgrades will be qualified by VZ and then pushed to users.
  • Case850 wrote:
    According to Netgear the Orbi is designed for "Networking Novices" to quickly establish a Wi-Fi home network. The trade off is the Orbi has low performance and is lacking a number of features one might expect from a router sold to the consumer market.
    They may be marketing Orbi as easy to configure. However, many Orbi users are not networking novices by any stretch of the imagination.
    Many simply want a whole home wifi system (Orbi RBK53 comes to mind) that performs better than competitors for overall performance (throughput and range combination) as per comparison reviews on smallnetbuilder.com.
    Orbi is certainly not a low performance system - In fact I tried both Lyra and Velop whole home wifi systems previously and neither could compete with Orbi as far as its wireless performance for range & throughput combined is concerned.
    I'll take performance over advanced features that I do not need. I understand some users need specific features that may not be offered byt Orbi.
