indianking
Jan 30, 2023Guide
RBK 50 transmit power control
I have an RBR50 + 2 satellites with the latest firmware. Moved homes - have a 1 Gbps internet connection. The apartment I moved into is smaller than my earlier multi storey house. I get 500- 600 Mbps...
Jan 30, 2023Guru - Experienced User
You won't hit 866mbps. That's link speed. Actual throughput tends to be 55-65% of what link speed is.
so if you're hitting 500-600mbps, you've pretty much maxed it out.
How big is the current apartment?
You might be better with disabling a satellite (not sure how many you have).
And they need at least 30ft between router/satellites to roam properly. that might be part of the issue to.
You can experiment with turning down the transmit power. It might help. All you can do is try.
indianking
Jan 30, 2023Guide
Thanks for the response. My current apartment is a bit more than 2200 sqft and I have a router plus 2 satellites. Many walls though :-). So just one satellite won't work. I used the orbi app to detect signal strength from the router before placing the satellites. I have good wifi coverage but it is too sticky when moving between satellites. So was thinking of reducing transmit power to see if the switching of roaming devices can be seamless. Hence the question to experts in the community .
- plemansJan 30, 2023Guru - Experienced User
Its worth trying.
I'd also check to see if you have it setup in a star configuration or daisy chained.
Star: satellite<------router----->satellite
daisy: router------->satellite-------->satellite
- indiankingJan 30, 2023GuideThanks.. I have disabled daisy chain. It is star config..
- FURRYe38Jan 30, 2023Guru - Experienced User
Definately worth trying 50% on the RBR. For that size of home only 1 RBS is really needed, however if building materials are being a factor, then ya, two RBS would be needed however I would turn down the Transmit power to help get the wifi signal over lap under control and help with devices connecting to the RBS rather than the RBR. I'd start with 25% first and see how it goes.
indianking wrote:
Thanks for the response. My current apartment is a bit more than 2200 sqft and I have a router plus 2 satellites. Many walls though :-). So just one satellite won't work. I used the orbi app to detect signal strength from the router before placing the satellites. I have good wifi coverage but it is too sticky when moving between satellites. So was thinking of reducing transmit power to see if the switching of roaming devices can be seamless. Hence the question to experts in the community .- indiankingJan 30, 2023GuideThanks a ton for the suggestion..I just changed it to 50%. Need to watch stability of the system and the reliability of the switching. I also need to test if the network throughput is compromised.
