indianking
Jan 30, 2023Guide
RBK 50 transmit power control
I have an RBR50 + 2 satellites with the latest firmware. Moved homes - have a 1 Gbps internet connection. The apartment I moved into is smaller than my earlier multi storey house. I get 500- 600 Mbps...
Jan 30, 2023Guru - Experienced User
Its worth trying.
I'd also check to see if you have it setup in a star configuration or daisy chained.
Star: satellite<------router----->satellite
daisy: router------->satellite-------->satellite
indianking
Jan 30, 2023Guide
Thanks.. I have disabled daisy chain. It is star config..
