FuzzyJohn
May 09, 2018Tutor
RBK-50 v2.1.4.10 and Logs
Since my Orbi RBK-50 had its firmware automatically upgraded to v2.1.4.10 the logs emailed to me contain gaps. I normally have the logs emailed when the log is full. I also tried toemail them daily w...
Brain29
May 09, 2018Apprentice
maybe your orbi crashed
use .. your - ip /debug.htm
I would also contact support and ask them about the beta firmware program they have - they have been working on allot of fixes for things
- FuzzyJohnMay 09, 2018Tutor
If the Orbi crashed wouldn't I see [Initialized] entries in the log following the crash? Last [Initialized] was after the firmware upgrade.
- JeremyinsfMay 09, 2018Apprentice
I've also had some log problems via email for the last two versions. I've received an email that was totally blank and also had truncated information like you, and had other cases where the log is cleared as though it was sent but I received nothing at all. (And no it's not in junk email or something like that)
But, sometimes the logs come in fine.
- thombeMay 14, 2018Apprentice
I get the same.
my logs now simply so "" and that is all, i have it set to send a daily email at 10am.
