FuzzyJohn
May 09, 2018Tutor
RBK-50 v2.1.4.10 and Logs
Since my Orbi RBK-50 had its firmware automatically upgraded to v2.1.4.10 the logs emailed to me contain gaps. I normally have the logs emailed when the log is full. I also tried toemail them daily w...
May 17, 2018Guru - Experienced User
Try a factory reset and set up from scratch next time your updated to most current FW to see if logs are still buggy. If they are then report it to NG support.
- FuzzyJohnMay 17, 2018Tutor
If I do a factory reset can I use a saved configuration or do I have to start from the ground up?
- FURRYe38May 18, 2018Guru - Experienced User
First save off a new save config to file. Then factory reset and set up from scratch and don't load the saved file. First check log behaviors to see if problem continues or not.
