JaneCKL
Aug 15, 2018Aspirant
RBK 50 what add on satellite to purchase and will it work?
Hello,
I would love some help as I have no idea what I am doing! Here is our situation:
4 level home comprising of:
Basement - wifi router and Orbi router located here
Ground - Or...
JaneCKL
Hi Stephen,
Thank you so much for taking the time to reply to my message. I really appreciate it. I will purchase the model you recommend and if it doesn't work will try and move the router to a higher floor.
Thanks again,
Jane
mdgm-ntgr
Aug 15, 2018NETGEAR Employee Retired
There are Outdoor satellites as well if you need good coverage Outdoors.
As StephenB mentioned placing the router in a more central location in the house and/or using ethernet backhaul would be advisable.
Whilst you can daisy chain Satellites (though with concrete walls that would be challenging) if a star topology works for your environment that would probably be better. See What is daisy chain and how does it work with my Orbi WiFi System?
