IanWZ
Apr 14, 2019Follower
RBK 50
Hi, I have an Orbi network (RBK 50) working for some months already, the router is in the 1st floor and the satellite (only one until now) in the 2nd floor. My Sonos Beam (no additional devices ...
Apr 15, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
