Spindlefish
Jan 05, 2021Aspirant
RBK 53: First time set up : firmware update / ethernet backhaul
I have an Orbi RBK53 (RBR50 and two RBS50's). I'm going to use an Ethernet backhaul connection. The user manual states: 'Before you set up an Ethernet backhaul connection, make sure that you upd...
- Jan 06, 2021
If your seting up the RBR in AP mode, what you can do is to not connect the RBR to the ISP modem at this point. Just wire connect one PC and walk thru the setup wizard. I will ask you if you want to manually setup the router. Manually set up the the RBR first with the wired PC. Complete the short wizard and get to the main web page. Find Advanced Tab/Advanced Settings/Router+AP mode. Select this and then select AP mode here. You can apply the setting and the RBR will reboot. Then connect the RBRs WAN port to the ISP modem. The RBRs access page may change so you can try re-acceccing it at orbilogin.com or find the IP address given to the RBR from the modems connected clients page.
Once the RBR is in ap mode, you can setup the wifi SSID name and PW for your needs, then go to sync up the RBS.
Jan 05, 2021Guru - Experienced User
Before you ethernet connect the RBS, besure to first sync the RBS wirelessly to the RBR. Then after, connect them wired.
Yes, before updateing FW, it's best and recommended to update the RBS FW first, then the RBR lastly.
Let us know what FW version you have on the RBR and RBS before proceeding with a FW update.
- SpindlefishJan 05, 2021Aspirant
Thanks for the fast reply Fe38
You found my 'chicken and egg' moment. I can't say what Firmware version I have until I switch everything on...
I wasn't sure the best way to access that info!
ISP ONT is a Orange Livebox Fibre, manufacturer 'Sagemcom', model 'SagemcomFast5656OFR'.
I'll do as you suggest and sync the RBS to the RBR using WiFi to begin with...
bit late tonite to play havock with my network so I'll post again tomorrow morning with the firmware version before updating.
Best wishes, Spin
- FURRYe38Jan 05, 2021Guru - Experienced User
Regarding your ISP modem. May have a built in router and wifi already, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopGood Luck.
Oh what joy. The ISP modem does indeed have a built in router and wifi.. which very helpfully does not have the ability to operate in bridge mode.
I'll have a go at your option 2, but I'm not too confident about altering DMZ settings due to my basic network knowledge.
The KB article related to your point 3 is pretty clear... between 2 and 3, which would be the better route?
Thanks again
