Spindlefish
Jan 05, 2021Aspirant
RBK 53: First time set up : firmware update / ethernet backhaul
I have an Orbi RBK53 (RBR50 and two RBS50's). I'm going to use an Ethernet backhaul connection. The user manual states: 'Before you set up an Ethernet backhaul connection, make sure that you upd...
- Jan 06, 2021
If your seting up the RBR in AP mode, what you can do is to not connect the RBR to the ISP modem at this point. Just wire connect one PC and walk thru the setup wizard. I will ask you if you want to manually setup the router. Manually set up the the RBR first with the wired PC. Complete the short wizard and get to the main web page. Find Advanced Tab/Advanced Settings/Router+AP mode. Select this and then select AP mode here. You can apply the setting and the RBR will reboot. Then connect the RBRs WAN port to the ISP modem. The RBRs access page may change so you can try re-acceccing it at orbilogin.com or find the IP address given to the RBR from the modems connected clients page.
Once the RBR is in ap mode, you can setup the wifi SSID name and PW for your needs, then go to sync up the RBS.
Spindlefish
Thanks for the fast reply Fe38
You found my 'chicken and egg' moment. I can't say what Firmware version I have until I switch everything on...
I wasn't sure the best way to access that info!
ISP ONT is a Orange Livebox Fibre, manufacturer 'Sagemcom', model 'SagemcomFast5656OFR'.
I'll do as you suggest and sync the RBS to the RBR using WiFi to begin with...
bit late tonite to play havock with my network so I'll post again tomorrow morning with the firmware version before updating.
Best wishes, Spin
Jan 05, 2021Guru - Experienced User
Regarding your ISP modem. May have a built in router and wifi already, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Good Luck.
- SpindlefishJan 05, 2021Aspirant
Oh what joy. The ISP modem does indeed have a built in router and wifi.. which very helpfully does not have the ability to operate in bridge mode.
I'll have a go at your option 2, but I'm not too confident about altering DMZ settings due to my basic network knowledge.
The KB article related to your point 3 is pretty clear... between 2 and 3, which would be the better route?
Thanks again
- FURRYe38Jan 05, 2021Guru - Experienced User
Easiest would be #3.
At somepoint you might find someone with more networking experience to help you try #2 if you want the Orbi to be in router mode and use more features it has. #3 will disable most of the features of the RBR.
- alokeprasadJan 06, 2021Mentor
FURRYe38 wrote:Easiest would be #3.
.... #3 will disable most of the features of the RBR.
It'll lose its NAT and port forwarding, and other fancy stuff, but it should still function as a basic mesh wifi system, right?
