Julianne
Oct 21, 2020Aspirant
RBK 53S
We purchased the RBK53S in the fall of 2019. It is a great system. We recently moved out of state and it seems the movers packed only the two satellites and not the router. I've tried everywhere t...
Oct 21, 2020Guru - Experienced User
Have to look online to see where you might find a another RBR50, Amazon, eBay, Not sure if NG shop is shipping any 50 series...
The shippers should be checked on this. They should be re-embursing you for this...
- JulianneOct 22, 2020Aspirant
Thank you for replying. I've tried E-Bay, Amazon, Netgear etc. No one sells the RBK 53S base separately. I'm still hoping..
- FURRYe38Oct 22, 2020Guru - Experienced User
Well you can use RBS20, RBW30, RBS40v, RBS50, EX7500/7700 and 8000 last last resort.
Stock maybe out or limited due to current world events. :smileyfrustrated:
- DeanB1452Oct 22, 2020Apprentice
Julianne,
I have the RBK53S system. The "K" indicates the bundle. The router is RBR50 and the satellites are RBS50. There are plenty of routers on eBay. Just do a search for RBR50 to purchase the router separately. You may also find some bundled with a satellite, so if you want to get an additional satellite, that is the way to go too. Good luck!
That is good, intelligent information. I will change my search to RBR50.Thank you.
