masterlau's avatar
masterlau
Follower
Apr 04, 2020
RBK 852 - WAN aggregation
I'm looking to leverage the WAN aggregation feature on my RBK 852 (2.5 Gbps + 1 Gbps, LACP-IEEE802.3ad), potentially through two 1000Mbps FTTH connections.    I'd like to know: (1) If both connect...
  • FURRYe38's avatar
    Apr 04, 2020
    Please post about this over in the Orbi AX forum:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Review the user manual.
    Good Luck.
    I'd like to know:
    (1) If both connections are from the same ISP but via different modems, whether I need any configuration from my ISP end - e.g. bonding.  What will happen if I simply plug in the two cables after setting things up on the Orbi webpage?
    (2) If both connections from the same ISP and via the same modem (i.e. 2 ethernet cables come out from the same modem), do I need specific settings on the modem?  What will happen if I simply plug in the two cables after setting things up on the Orbi webpage?
    (3) If the two connections are from 2 different ISPs, would that work? Is it possible to make it work?
    Any thoughts and advice would be most welcome! Thanks!
    ML
