iguschan
May 27, 2021Follower
RBK12 Router is getting 600mbp but wireless gives no more than 400mbps
I have an RBK12 Orbi WIFI Router is getting 600mbp from the ARRIS modem. The wireless gives no more than 400mbps. I have tried the cable connected to the router and its ok. The wireless does not g...
May 28, 2021Guru - Experienced User
300-500Mbps is the max range for anything on 5Ghz AC. ALso depends on devices design and support as well. Most 2x2 MIMO devices are in this range. A device with 4x4 support can support much higher speeds.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
https://www.smallnetbuilder.com/wireless/wireless-features/33229-how-much-total-throughput-can-your-wi-fi-router-really-provide?start=0
iguschan wrote:I have an RBK12 Orbi WIFI Router is getting 600mbp from the ARRIS modem. The wireless gives no more than 400mbps. I have tried the cable connected to the router and its ok. The wireless does not give more thatn 400.
I also have in another home a NIGHTHAWK R6700V2 where the modem gives me 300mbps and the wireless gives me the same.
does the RBK12 does not pass thru the same speed?
Support did not help, they told me the wifi would never give you the same. I can leave with some degradation, but that much?
Your input would be greatly appreciated.
Thanks
