Lightfoto
Mar 05, 2020Aspirant
RBK12 Wifi shut off at night
RBK12 Orbi AC1200 Dual-Band Mesh WiFi System 2 pack I wonder if it is possible to shut off the wifi at night by schedule. I am thinking about buying one but I can’t find this feature in the online ...
Retired_Member
Mar 05, 2020
I wonder if it is possible to shut off the wifi at night by schedule. I am thinking about buying one but I can’t find this feature in the online manual.
Not sure why you want this, but you may want to keep in mind that IF your SATS are using WIFI and you have the ability to shut that part (WIFI) of your network off at night, the SATS may miss out on critical FW updates from NG. That would be the ones that NG pushes auto-pilot.
Lightfoto
Mar 06, 2020Aspirant
Thank you all for your reply. Guess a timer is indeed the best option to shut it off.
