routerks
Nov 16, 2020Tutor
RBK13 - Product suggestions
Hi, I am living in 1500 sqft apt and need sugesstions on using "RBK13 — Orbi AC1200 Dual-Band Mesh WiFi System 3 pack" My internet speed is 200mbps, can i know if this router can handle this and...
Nov 16, 2020Guru - Experienced User
it should be able to.
But you might be better off with more powerful single router solution versus using a dual band mesh system for that size home.
I'm a fan of mesh systems but if the home isn't large enough, it can create more problems than it fixes.
