routerks
Nov 16, 2020Tutor
RBK13 - Product suggestions
Hi, I am living in 1500 sqft apt and need sugesstions on using "RBK13 — Orbi AC1200 Dual-Band Mesh WiFi System 3 pack" My internet speed is 200mbps, can i know if this router can handle this and...
Nov 16, 2020Guru - Experienced User
it should be able to.
But you might be better off with more powerful single router solution versus using a dual band mesh system for that size home.
I'm a fan of mesh systems but if the home isn't large enough, it can create more problems than it fixes.
routerks
Nov 16, 2020Tutor
Than you very much for the response. Can you suggest some routers that helps as I have issue with my current router having some dead spots without internet or frequently dropping.
FYI..I am currently using verizon quantum gateway.
- FURRYe38Nov 16, 2020Guru - Experienced User
Maybe a EX model extender is all you need to add on to what you currently have...something like a EX7500 or 7700...
