routerks
Nov 16, 2020Tutor
RBK13 - Product suggestions
Hi, I am living in 1500 sqft apt and need sugesstions on using "RBK13 — Orbi AC1200 Dual-Band Mesh WiFi System 3 pack" My internet speed is 200mbps, can i know if this router can handle this and...
routerks
Nov 16, 2020Tutor
Than you very much for the response. Can you suggest some routers that helps as I have issue with my current router having some dead spots without internet or frequently dropping.
FYI..I am currently using verizon quantum gateway.
Nov 16, 2020Guru - Experienced User
Maybe a EX model extender is all you need to add on to what you currently have...something like a EX7500 or 7700...
- routerksNov 16, 2020Tutor
Thanks for response.. Can i know whether I have to take EX7500 or 7700... on top of RBK13.
- FURRYe38Nov 16, 2020Guru - Experienced User
The EX would not be needed if you install a RBK1 series system.
Thank you very much for the reponse and I will try witb RBK13.
I have read in some of netgear comparisions that this can support upt 100mbs speed so have a question whether the router can handle 200mbps internet speed from verizon.
Kiran
