routerks
Nov 18, 2020Tutor
RBK13 -Satellite disconnnecting frequently
Hi, I have installed RBK13 couple of days back and one of the satellite is disconnecting regulalry . Once i click on sync in both router and satellite2 it is connecting, after some time it is di...
Nov 18, 2020Guru - Experienced User
What happens if you swap locations with this 1 RBS with one of the other RBS?
routerks
Nov 18, 2020Tutor
Hi,
Can you clarify what does changing the location of RBS . Do you want me to swtich the RBS.
Thanks,
Kiran
- FURRYe38Nov 18, 2020Guru - Experienced User
Yes...swap RBS around.
- routerksNov 18, 2020Tutor
Thank you I will try to swap today and check .(am not sure how it matters as both are new satellites).
Can i know if any other setting we have to change like Daisy/beamify etc...
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
