routerks
Nov 18, 2020Tutor
RBK13 -Satellite disconnnecting frequently
Hi, I have installed RBK13 couple of days back and one of the satellite is disconnecting regulalry . Once i click on sync in both router and satellite2 it is connecting, after some time it is di...
routerks
Nov 18, 2020Tutor
Hi,
Can you clarify what does changing the location of RBS . Do you want me to swtich the RBS.
Thanks,
Kiran
Nov 18, 2020Guru - Experienced User
Yes...swap RBS around.
- routerksNov 18, 2020Tutor
Thank you I will try to swap today and check .(am not sure how it matters as both are new satellites).
Can i know if any other setting we have to change like Daisy/beamify etc...
- FURRYe38Nov 18, 2020Guru - Experienced User
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026- routerksNov 21, 2020Tutor
Thank you very much for the document, it is really useful for knowing the configuration.
But after following these instructions i am having these two issues -
- Now the it is not disconnecting frequently but early in the morning one of the satellite light turns light without any signal
- When i am next to the satellite still my laptop is connecting to the router and network is very slow. Is there any configuration that picksup the signal from the nearest satellite instead of router.
Thanks,
Kiran
