Bendegeit
Jul 30, 2021Aspirant
RBK13 and Firestick = bad TV?
I have a 3-level home with 5 people, 5 phones, 4 computers, 2 firesticks, and 1 printer. High Speed (100) Internet from Spectrum.
I've installed the Orbi RBK13/AC1200 with one the main router by the modem, a satellite upstairs at the wall between two bedrooms, and the second in the basement beside the printer. At no time are all accessing the internet at once.
The phones and Firesticks connect via wifi at 5gHz.s
I have performed several speed tests with my gear, wirelessly, and they all show excellent downspeed meeting or slightly exceeding the promised level.
In spite of this I am frequently frustrated by really bad TV signal through my firestick (right next to my Orbi router) which frequently produces something akin to you-name-the-show rendered in a Cubism meets Renoir filter and which is only briefly interesting before becoming completely unwatchable.
Orbi reports the firestick talking to it at 5gHz band (recommending no more than 4 devices?) but the firestick complains saying that it can't supply really good images at 2.4gHz.
Is my Orbi a dud? Or do I have the wrong system for my house?
Orbi seems to tell me
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡How close is the Firestick/TV to the RBR?
What happens if you turn OFF The RBS, leaving the RBR online?Can you try swapping firestick around on this TV?
- BendegeitAspirant
Hi FURRYe38.
To answer your questions:
Spectrum equipment:
Modem/Router: Cisco DCP3216
Wireless router: removed N/A
No extraneous connections outside of the Orbi
Orbi
Firmware: v2.7.3.22
RBR - RBS1 distance: >30
RBR - RBS2 distance: +- 20
Home:
Sq Ft: approx 2900 = 1100, 1100, 700.
70's construction
Firestick to Orbi > 3FT
I have swapped the Firestick once before and this Firestick seemed to work better than the previous one.
Powering down the closest RBS does not seem to fix it.
For what its worth, I picked up the Orbi system specifically to try to correct connectivity issues in the girls bedrooms and with printer. the Orbi seems to have helped with those issues somewhat but my hi def video is still frequently poor.
3 feet is a bit too close between the firestick and RBR. Try 10 feet.
RBR - RBS2 distance: +- 20 < Try 30 feet or turn this one OFF and test.
