rdhdiver
Mar 23, 2020Aspirant
RBK13 assignment of devices to main router and satellites
I just purchased and installed my new Orbi RBK13, "whole home" WiFi System. The setup was easy but I don't like it that i cannot control which devices connect to the router and its two satellites. I have a router satellite 8 feet away from my office desk, but my laptop is listed as being connected to the router which is upstairs, far away from the computer. At one point it was connected to the satellite near it. How does Orbi assign devices to its central router and two hubs? I would like to be able to assign devices to hub and satellites. Earlier today, it made sense that 2 cell phones, an iPad, and 3 laptops were connected to each of 3 devices by logical proximity. They seem to have migrated connections, but I haven't moved any of the devices. Is there a way to statically assign devices to satellites and even dictate whether to use 2.4 GHz or 5 GHz?
Alas, no. There is no method to force device to connect to a particular access point. There are industry standard protocols about how devices detect nearby access points and decide which they will use. Orbi follows the standards. The important question is, "Are the devices functioning correctly?" If so, there is actually no reason for concern. Things like phones, tablets, and laptops may "move" becauses their network software is written with movement in mind. Devices designed to remain in one place almost never change access points once they have attached to one.
I am not (personally) aware of any mesh router systems which feature this ability, certainly not easily.
- rdhdiverAspirant
My personal laptop stays in my office, 95% of the time. It hasn't moved today, yet it dropped from the satellite, 8 feet away in clear sight, and hopped onto the main router upstairs and far away. This defeats the purpose of having bought the mesh network. Most of my devices were connected to the satellites downstairs, but now there are a few connected to the furthest away device. It is a matter of performance and having the satellites were providing me great performance while they were connected.
Do you use the Orbi web interface or the Orbi "app" to administer the Orbi. The "app" will show the "Link Rate" between the device and Orbi unit.
I understand the concern. How has performance changed?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerTry setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
rdhdiver wrote:I just purchased and installed my new Orbi RBK13, "whole home" WiFi System. The setup was easy but I don't like it that i cannot control which devices connect to the router and its two satellites. I have a router satellite 8 feet away from my office desk, but my laptop is listed as being connected to the router which is upstairs, far away from the computer. At one point it was connected to the satellite near it. How does Orbi assign devices to its central router and two hubs? I would like to be able to assign devices to hub and satellites. Earlier today, it made sense that 2 cell phones, an iPad, and 3 laptops were connected to each of 3 devices by logical proximity. They seem to have migrated connections, but I haven't moved any of the devices. Is there a way to statically assign devices to satellites and even dictate whether to use 2.4 GHz or 5 GHz?
