dl42
May 22, 2021Aspirant
RBK13 Firmware update problems
Anyone else seeing any issues with Firmware Version 2.6.2.104 on RBS10 and RBR10? My RBK13 (AP mode) setup would stop working - no wifi connectivity - about once a day after upgrading to this versio...
Blanca_O
May 27, 2021NETGEAR Employee Retired
Hi dl42
As suggested by FURRYe38, have you tried factory resetting the device?
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
- dl42May 28, 2021Aspirant
Not as yet.
Wanted to just validate that the issue was the fw and not something else(hw?) as it dod seem to be random.
Looks to be the case as everything has been solid again since I reverted to the old fw version.
Will try and find time to do the factory reset - though why it should be needed is another matter.
I take it I'm the only one seeing this issue? Is it because I am running in AP mode?
- dl42Jun 04, 2021Aspirant
The factory default and then update seems to have resulted in a solid network once more.
- FURRYe38Jun 04, 2021Guru - Experienced User
Enjoy.
