dl42
May 22, 2021Aspirant
RBK13 Firmware update problems
Anyone else seeing any issues with Firmware Version 2.6.2.104 on RBS10 and RBR10? My RBK13 (AP mode) setup would stop working - no wifi connectivity - about once a day after upgrading to this versio...
dl42
May 28, 2021Aspirant
Not as yet.
Wanted to just validate that the issue was the fw and not something else(hw?) as it dod seem to be random.
Looks to be the case as everything has been solid again since I reverted to the old fw version.
Will try and find time to do the factory reset - though why it should be needed is another matter.
I take it I'm the only one seeing this issue? Is it because I am running in AP mode?
dl42
Jun 04, 2021Aspirant
The factory default and then update seems to have resulted in a solid network once more.
- FURRYe38Jun 04, 2021Guru - Experienced User
Enjoy.
